Gemini Gulf Stone Tiles
2 Mar 2008
Northumberland
Hi Guys,
Im a plumbing and heating engineer , done fair bit of tiling, my sister wants a new bathroom she has picked the gulf stone tile, u know the one with the sparkles in .Any advice on the installation of these ,adhesives , grouts, do i need to seal.I was thinking of a rapid set , and flexi black grout, as its the Black opal colour.Any thoughts would be much appreciated.
Cheers
Are you tiling the floor, walls, both? What are they; concrete, suspended timber, plasterboard over stud, plaster over block? Any wet areas involved? What size/weight are the tiles?
Probably will need sealing, what does supplier say? They may even come pre-sealed; a water test will tell.
hi Richard ,they are going onto plywood floor in a bathroom , but not a wet room so shouldnt be that much water involved,interested in the adhesive and laying method on these if possible.
BAL Rapidset flexible or Single Part Flexible; apart from being ply, you didn’t say what the floor is but if there is any doubt about floor rigidity, Single Part Fastflex but that stuff will make a hole in your sister’s purse. Microflex or Superflex grout. Use a thick bed solid bed trowel - 20mm round notches, 10mm deep, at 28mm centres. I use BAL exclusively but there are other adhesive brands equally as good, just avoid cheap own brand/DIY adhesive/grout, it’s mostly crap. Do not prime the ply before tiling.
As before seal the tiles if necessary & be careful not to scratch them when grouting.
