Hi guys last week at auction i bough a
suntom sde6500t diesel generator there a Chinese Genny but not to bad.
There was no battery on it at the time so bough it on sold as seen and someone stole the keys from it after i had purchased it meaning i had to buy a new ignition switch.
After the new ignition switch came i switched it with the one fitted and attached a 12v car battery and fired up the generator it fire up and ran ok , i switched it off then went to fire it up again and it ran for a second or two then died and there was now nothing when you turned the switch...
when i took the control panel back off i seen that the wires on the new ignition switch were all melted likely why there was nothing when i now turned the key
can i ask though what would of caused the Wiring to all melt after only just fitting
was a carry battery to big of battery ?
also what is the black lever for inside by the engine that has a few copper strands wrapped round
any help would be very helpful
cheers
cheers
