- Joined
- 25 Apr 2023
- Messages
- 9,222
- Reaction score
- 6,348
- Country
If ya like, well of it excuses an Afghan rapist atleast you'll be happy....see yaMore tiresome lies.
Of the fact you declared your love for a rapist?
1 is too many. Are you happy with 1 or would you be ok with more. What number will you not be ok with. Do you even care so long as the indigenous population do more.“All too common”
How many exactly?
And that's the bleedin point, that you constantly fail to grasp, we know their crime history.It wouldn’t surprise me if there’s was more sexual assaults by flag protestors.
40% of those arrested at last years Farage riots had previous for donestic violence.
Notch-Bot7 is programmed not to care.1 is too many. Are you happy with 1 or would you be ok with more. What number will you not be ok with. Do you even care so long as the indigenous population do more.
But we know f all about the boat people who come from mainly lawless failed states where mental conditions go un diagnosed and rape is a way of life for some.
Have you got your wires crossed?That’s a tricky problem getting all connections to a common point (or “all-to-common”) can definitely create some headaches depending on wiring layout and load. One approach could be to use a junction box or terminal block in a central location, which gives you a clean spot to bring all the conductors together safely. Make sure to size your cables correctly for the current load and double-check all connections are solid and well-insulated. Good luck, and stay safe!
If you were 120 you still couldn'tI am 55, I don't recall when we lived in a crime free country.
Don't talk to people about what's right and wrong when you hold trump in such high regard.Coming from a BBC lover, I'll take no notice
Also not lying nosall![]()
Do what I like thanksDon't talk to people about what's right and wrong when you hold trump in such high regard.
You can.Do what I like thanks![]()
ThanksYou can.
Same as you lot the other way around1 thing is bad because it's an .....
2 thing is good because it's trump.
I dont expect anything from anyoneJust doesn't add up, so don't expect anybody to take you seriously. Or even consider your argument because you nullify it yourself.
No.Same as you lot the other way around
LolNo.
The correct argument is both are wrong.
Neither side makes the other right regardless of who it is.
I didn't expect awareness from you it's ok
What's your problem with me anyway?I didn't expect awareness from you it's ok
It's just banterWhat's your problem with me anyway?
I was not hassling you minding my own business
