Getting kickboard replaced and making it more rodent proof?
8 Oct 2018
I won't be doing this myself as I am useless at anything to do with DIY - but in my kitchen (please excuse the general state of it!), I have a kickboard that's been loose for some time. There are some gnaw marks on the top of part of it which would indicate rodents had a good go at it, so it'll be replaced. There are also some gaps that have appeared in the laminate floor next to it (see photos) so I do fear that rodents have had a go at that too - ideally I'd get them sorted too.
I haven't heard any rodent activity for some time but am aware that we're in the part of the year where they'll be coming inside more often so should get it all sorted ASAP. I'll get a handyman/carpenter to sort out the kickboard (I presume I just take measurements and buy it which they'll trim down) but would they also usually be able to rodent proof around there or should I get in a rodent specialist?
It would make sense to get someone to push wire wool into any gaps between the floorboards and the wall under the cabinets. Rats need to chew things constantly otherwise the front teeth become too long. Apparently, they will avoid wire wool because it cuts their nose. You can then double that up with expanding foam to deter smaller insects (and draughts).
