    Dismiss Notice
getting rid of artex
Discussion in 'Plastering and Rendering' started by jeepmadmike, 30 Sep 2009.
  1. jeepmadmike
    jeepmadmike
    6 Jul 2006
    197
    Thanks Received:
    2
    Devon
    Country:
    In 2 weeks we should be moving,
    once we do i have a artex ceiling to get rid of! i was thinking the options are
    1 Get a plasterer to plaster over the artex.
    2 Sand or scrap off the high spots and get a plasterer to skin the area.
    3 Board the whole ceiling and again get it skimmed.
    4 Sand it down, fill it, mess around with it for days......
    what do you guys recon?
    btw the room is 4mx8m
  2. Sponsored Links
  3. Alastairreid
    Alastairreid
    21 Nov 2008
    6,259
    Thanks Received:
    970
    uk
    Country:
    thats your answer. ;)
  4. trowelmonkey1
    trowelmonkey1
    22 Apr 2009
    857
    Thanks Received:
    82
    Oxfordshire
    Country:
    last option you want is sanding! for many reasons, the most important is that it could contain asbestos so leave well alone.
    it's possible to steam it off like you would wallpaper but depends on the paint you have on it and it's messy, but would mean that there's no chance of it failing when being plastered, albeit a small chance.
    so overall i agree with AR, just make a call and get it done for you.
  5. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    999
    Country:
    Agree with the others :LOL:
  6. dark_stranger
    dark_stranger
    9 Jun 2005
    72
    Thanks Received:
    Kent
    Country:
    I heard that skiming over artex can caause problem with the new plaster due to air bubbles, etc or is this the worse case? as I am actually trying to get rid of artex ceilings aswell.
  7. Sponsored Links
  8. Micilin
    Micilin
    6 Oct 2007
    2,883
    Thanks Received:
    307
    Bedfordshire
    Country:
    You can get a problem if you don't seal up the artex at least the day before with diluted PVA or SBR; or use Bondit etc. The Artex may get damp and come away from ceiling. Old paper tapes may also come away if damp gets to them.
    Apasrt from that, as the others say, then no worries
  9. Alastairreid
    Alastairreid
    21 Nov 2008
    6,259
    Thanks Received:
    970
    uk
    Country:
    scrape off any loose/flaking artex then a couple of coats of pva, let it dry overnight, then another coat of pva let it go tacky then plaster.
    if the artex is that heavy a coat of bonding plaster first if required.
    beat me to it micilin. :D
  10. Micilin
    Micilin
    6 Oct 2007
    2,883
    Thanks Received:
    307
    Bedfordshire
    Country:
    There's a first time for everything!
  11. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    One thing you have to watch for is that the ceiling may have been artexed because it was in poor shape. If the artex pattern is deep then you'll need a lot of plaster. If you use 4 bags then that weight is more than your body weight. Will your old cracking ceiling take your body weight - or will the whole lot come down? Press the ceiling to see if it is firm. If it has lots of sag then it might be an old lath and plaster ceiling that is failing. If the house is modern then it was just done as a 'feature' and you can go ahead ok.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
