Can you get, e.g. DIN rail mount, brackets to allow a SWA gland to be fixed within an enclosure?
You can get an enclosure c/w DIN rail fitted and an assortment of terminals with adequate space for the termination of one or more SWA glands.
'Electonicsuk', I'd gladly provide a link to an enclosure with a DIN rail, but the thing is I just don't know how to cut and paste or provide anything other than a simple link which I have to type out laboriously in longhand.
Can you manufacture a 90 degree metal bracket, drill a 20mm hole (if that's the size required) in one side and mount the other to the backplate?
Yes - I could do those things, and I could probably find something knocking about that's already the right shape and only needed cutting to size and a few holes made. I just wondered if anything ready made was out there.Why don't you get a suitable small piece of sheet metal, form a 90degree bend in it using a metalwork vice, drill a hole to suit the gland, and then pop rivet it into your enclosure... earth to the metal to be provided to lug bolted onto the banjo tag on the SWA
I'm not struggling with the concept of an enclosure with a DIN rail in it.I'd like to remind BAS that he has used such an enclosure, because he posted a photo in another place showing such a thing when he devised a fan overrun connected to a shower circuit for his own house.
Apparently not.I have still a reasonable memory........
I don't know if you think you're being quaint, with laments like that and your persistent claims that you have no idea what emoticons or smilies are for, but you aren't - you're being pathetic.'Electonicsuk', I'd gladly provide a link to an enclosure with a DIN rail, but the thing is I just don't know how to cut and paste or provide anything other than a simple link which I have to type out laboriously in longhand.
I'm not much good at I.T. at my age
