- Joined
- 24 Aug 2009
- Messages
- 2,664
- Reaction score
- 281
- Country
Hi
I am considering making a bedroom wall of glass as above. The room is 8 m above ground-level and not overlooked but has phenomenal views.
Can you give me any tips on what the technical limitations for making windows is i.e. does it suddenly become much more expensive when you exceed certain dimensions ?
I have certain unusual factors. I live at 1400 m in the N. Alps and would normally be looking at triple-glazed, but think that would be a step too far - correct ?
We do not often experience storms but they can be violent when we do. The other night we had winds of around 80 mph and my house is completely exposed on the side of a mountain. The proposed wall would be in an angle of the house so would more likely be more exposed to suction than positive pressure.
Approx what U -values can be achieved these days with argon and low-e ?
Can you recommend any web-sites/forums that deal with this ( large areas of glazing )?
Since I have more or less single-handedly renovated this large stone-barn over a number of years, I am naturally considering the possibility of installing this myself.
Apart from that, this is a remote area with no real specialists so I would have to travel a fair distance ( 100 miles each way ) to get to a large city with companies who could likely help.
If someone could give a guide on price this would show me if it is worthwhile investigating further i.e. if it is GBP 200 per m2 I would go ahead but if it were GBP 800 per m2 - not inc fitting - then I wouldn't.
Thanks in advance
Forgot to say that since the wall will be to floor level then it would require toughening as a normal glazed-unit or would this be standard when you start dealing with large dimensions ?
Thanks in advance
