Hi all.
I finished fitting a composite door this afternoon which has a glass sidelight attached to the frame. It's a upvc frame and I've hit a massive snag trying to glaze it. I can't get the beads in after hours of trying and I've tried everything.
I've fitted a canny few upvc windows in the past and while glazing beads can be awkward I've never found them to be impossible. This bead has to be pressed down to engage the tab that runs it's full length with the slot in the frame. The problem is it also has to be pushed in to engage the front lip on the frame and as it goes in the glass forces it up so the tab passes over the top of the slot.
It's hard to explain but the profile is in the attached link from the door makers website. I've hit the beads from all angles while pressing down hard and pushing in but I can't even get the short ones to start. This is all before I reach the problem of the frame fixing screw heads that are in the way as well. I reckon I'd defy any man on this planet to get these beads in.
http://www.justdoorsuk.com/downloads/composite-cross-section.pdf
