Gloss paint care
27 Sep 2011
My decorator has left me half of a tin of Dulux High Gloss paint but he says he has lost the lid.
Is there anything I can do to stop the paint going off please?
JohnDL
Lol. how on earth do you lose the lid for a paint tin?
I'd suggest a couple of layers of cling film with an elastic band around the top to keep it as air tight as possible?
Thanks. They had 4 men painting at the same time so put the paint in 4 small plastic containers they used to go up ladders. They expected to use the whole tin so binned the lid and then didn't use all the paint.
Thanks for help.
JohnDL
You could always buy a paint kettle, which is what your painters will have used. They come with plastic lids (like tuppaware i guess). But they probably cost more than your paint is worth, so stick to the cling film :)
Thanks. The paint is already going a bit thick, what would be the best way to thin it down please?
Would you mind recommending a 1 litre paint kettle? There seems to be hundreds of them.
JohnDL
A painter will have to advise on thinning your gloss for you, but a paint kettle....is...err...a paint kettle. It's just tupperware (or metal) for paint. I really can't see there being big differences in quality.
Is there a lot of gloss paint left and is it expensive stuff?
If not, then it may not be worth all the fuss just to save it. Buy new!
Thanks. It's a discontinued colour and we had to have it scanned and mixed which also involved quite a long drive so it needs to be kept.
JohnDL
jam jar or pickle jar with tightly fitted lid. Wash out the old tin with a drop of your thinners and tip that into the jar.
Thanks.
Is white spirit thinners?
Thanks for help
JohnDL
White spirit is thinners for most oil paint. Some paints are thinned with water. If you can't tell, try a drop on a bit of stick or something.
Thanks, it's Dulux High Gloss
JohnDL
Hi John. That sounds like the oil-based version so will require white spirit to thin it. Easiest way to tell if it's oil-based is what the tin says to wash brushes in. Wash brushes in white spirit = oil-based paint = white spirit to thin paint / wash brushes in water = water based paint = water to thin paint.
Thanks Deccy and yes it says white spirit.
That's a great help thank you.
JohnDL
