Hi, hoping to get some help with this. have a glow worm 15 hxi bolier, controlled by a drayton dual channel programmer, when the programmer calls for hot water the boiler fires up and all is good. when the programmer calls for central heating, the boiler will not fire up. I have checked voltage in and out of programmer and all is ok, the thermostat is working and has voltage also. There are no fault codes showing just a temp. thought I had found the problem, with a sheared shaft on the 3 port valve, I have this morning replaced the 3 port valve and controller. but still have same problem with boiler not firing up with central heating is called for?
Any ideas or information would be greatly appreciated .
Read more: http://www.diynot.com/diy/threads/g...ing-not-working.414512/#3215178#ixzz3FvSbjktY
