Hi.
I have a Glow worm 24ci which is about 4 years old ish. Recently the flame would cut out if running hot hot water ((eg, shower). (I got completeley fed up of doing the hokey cokey in the shower). I spoke to a plumber who told me to up the pressure on the central heating side, and I did, and this problem went away. (now 1.5 bar)
But now the water just won't get hot enough. It used to be scalding (when running water at slower speeds), but now it stays at a constant temperature, just not hot enough, no matter the speed of the flow. Flame stays lit.
I have changed the water flow sensor (expecting no change) and there was no change. I am tempting to change the heat exchange for the DHW.
The heating is still fine. Can anybody please give some advice, before forking out loads of cash.
Thank you.
Thank you.
