Happy New Year To All!
This problem with my G.W. 30cxi started off as two problems at the same time, but the problem with the heating seems to have resolved itself. The h. w. problem still exists. Here's what happened;
HEATING
A week ago, I turned the room stat on, and after approx 8 minutes the boiler stopped. The heating was still a few degrees below what I had set the room stat at (18 degrees). After a while the boiler came on again for longer, but cut out again. In all, the boiler cut out approx 3 times before reaching the temp set on the room stat. Gradually this fault got better, and now seems to have disappeared.
HOT WATER
During an average shower, the h.w. goes cold three times. Each time, you have to turn the water off, wait a few mins, and turn back on. All hot taps run cold after a while if they are left running for a while. This fault started at the same time as the heating fault, and it is still happening.
Any ideas would be appreciated.
HEATING
HOT WATER
