Glow Worm 50FF intermittent Reset light on
9 Sep 2018
Hi, only been in this property a few months, the house/boiler is 14 years old and has recently had the fan replaced by previous owner. I had a problem a month back and was told it was the airpressure switch which was replaced. All good until a week ago with same steady red Reset light on.
Turned off at the isolator no joy, but I did open up the front panel and wiggle the connectors I could see and lo and behold it now works! I should add that my previous house had the 30FF boiler and I had many issues with that which went through 3 replacement pcbsbefore it gave up after about 8 years.
So, reading these forums I can see many problems with this model and changing the pcbmay not fix the root cause.
May I just ask though, a lot of posts say that changing the pcb. necessitates changing the thermistor as well? Just wondering why if anyone can explain please?
I was just wondering if it was worth spending money replacing bits when there are many possible causes and it may be easier - before winter arrives - to simply replace the boiler for around 2k.
Thanks for any ideas.
The thermistors can damage the pcb when they fault. I'd be trying much cheaper things first though.
Fair enough. Glowworm issued a technical note about 15 years ago saying they did....it was still on the bg laptops as a hint and tip when I left a couple of years ago.
