Glow worm boiler not firing for CH (works for HW)
13 Aug 2009
Nottinghamshire
Hoping someone can point me in the right direction ?
Firstly I`m not sure if this is relevant but I returned from a few days away and when I tried the boiler the fan had seized. I have lubricated this and it works fine when I select HW only.
I have checked the room stat and its working fine.
My thought was to put a link in the time clock plate to see if the time clock is not switching. Its a danfoss FP715si (5 wires connected to plate). Which "pins" do I need to link ?
What else could I look for - or do I wait until Wednesday for the engineer as it could be the PCB ?
:shock: :shock: :shock:
Calm down, diverter valve is probably sticking, wait for engineer to arrive and rip you off something shocking :lol: :lol:
You can change actuator head yourself if you can swap wiring like for like,it`s not difficult. :wink:
Diverter valve channel? on a gravity/pumped system?????.....Stick to collecting rent. :lol:
You sure it's gravity hot water OP?
Its a gravity hot water, pumped heating.
Boiler is a. Glow worm ultimate.
What controls do you have on the Central heating pipework
Perhaps just a gravity check valve or maybe a 2 port motorised valve?
If the latter it would most likely be a fault there which a replacement head would fix.
I'm as sure as I can be (that its gravity HW). How do I check ?
There is a 3 way valve. Does the bolier wait for this to change before starting ?
I didn't realise the boiler would wait for the valve to change.
I just removed the valve and replaced and it appears to be working. I also have a spare valve which someone gave me so will change if I get a further problem. Looks like the boiler insurance got away with it again !!!
Ay, Steelmason`s. You want one of these? :oops: :lol:
