Hi there
Looking for a little advice with my combi boiler problem before i dive in and start diagnosing
I`ve recently switched the boiler to `summer mode` and although it`s happened a couple of times intermittently, last night it became a permanent problem. When turning on the hot water tap the hot water would kick in and deliver the water as required and then shut off as soon as i turned the tap off. However,now the the pump is coming on and just cycling endlessly and not shutting off after i`ve turned off the tap !! I`m forced to actually switch the boiler off to stop it.
Has anyone experienced a similar problem and could they offer me any help with diagnosis ?
Any info would be much appreciated.
Alex
Alex
