- Joined
- 14 Jan 2019
- Messages
- 3
- Reaction score
- 0
- Country
Hi All,
Wondered if anyone can comment on this to help me diagnose a little problem I have. The above boiler has been in place for a good 2-3 years (possibly longer) and has given pretty good service for both hot water and heating. The only thing I have done is clean out the Magnaclean a couple of times a year and on one occasion a few years ago, clean sludge that had built up around the back of the PRV (on that occasion I was getting slow drop in CH pressure)
Anyway this recent occurrence is one of over pressure up to about 2.8 - 3.0 bar
I have dropped the pressure back down to 1 bar, using a drain valve at the bottom of the rad near the back door, but the pressure rises again especially once the heating has kicked in. I have dropped the pressure a few times and the first few times it did stay low for a while however it is now increasing pretty rapidly.
From past experience I believe there are only a few reasons for an increase in pressure;
* Water is adding to the CH side because the valve(s) on either side of the filling loop are weeping
* The expansion chamber is leaking or needs re-pressurising
* The heat exchanger is leaking internally and passing water to the CH side
Is there a sure fire way to diagnose this? Heat exchangers for this model aren't too expensive but I believe its a beggar to fit. I could test the pressure on the expansion vessel or indeed add some pressure to see if that made any difference?
I do not suspect the filling loop valve but again that would be relatively low cost to swap out.
I guess I could just swap the filling loop / valve then test the expansion vessel pressure before doing anything else?
Any help appreciated...
Tia!
Tia!
