Hi, i had an issue with water dripping from the bottom of the casing of the boiler. the condensate trap and flexible hoses and seals were replaced, but problem started again about after 1 week. and then stopped again after that.
Since then have had other issues with the system not working properly on high boiler temperature so boiler has been running at below 50c for last weeks and no leaking. The pump was replaced yesterday which sorted out the issue and now boiler happily runs above 50c but the leaking problem has immediately come back.
So am wondering its either to do with the water now being pumped at a faster rate (like it was a few weeks ago) or that when running on higher temp it produces more condensate which cant get away quick enough??
Any ideas from anyone with similar issue?
