Glow worm Micron
3 Oct 2007
Southampton
My boiler has stopped starting, if I turn on either the heating or hot water nothing starts, I can force it to start by turning it off then back on, but it only stays on for about a minute.
any ideas please?
Does it actually fire up, or do you just hear the fan spinning?
The fan does start, it also sounds like it fires up the gas but goes off and the fans restart.
Could be flame rectification problem. Check all leads are firmly attached, including the spark lead and earth leads. Could even be a slight possibility of a pcb problem.
If not this, then could be gas valve, which would need a RGI to check it out.
