hi everyone.
new to this site so bear with me.
i went to look at the above boiler earlier and it has a problem of the hot water not coming on all the time when it is called for.this problem does not happen all the time as it did not happen when i was there.
as the hot tap is opened and closed(especially closed) there is a slight banging noise which i presume to be coming from the flow switch as you the noise when tap is shut off is from the valve closing.
is it a matter of replacing the flow switch or will it just need a good clean.
i don't get involved in servicing and other boiler issues to often as the vast majority of my work is new installations and re furbs,as a result my servicing knowledge is slightly(!?) lacking
any advice would be greatly appreciated
cheers
matthew
cheers
matthew
