I had a power cut the other day and now my boiler won't relight. I've tried following the instructions on how to get the pilot to fire up but it won't have it. Any suggestions?
The pilot on these things can be a pig to relight.
Try lighting it with the power turned off.
If that does not work then the only way is to take the cover off and light with a match. (if you are competent that is )
Tip: DO NOT keep holding the grey button down and pressing the igniter for a long period..it WILL go with a BANG if it suddenly sparks
The fault will almost certainly be that the spark electrode is too close to the combustion case and it is arcing causing the spark to be in the wrong place.
