I have one of these decrepid boilers and was wondering why i can only get a trickle of hot water only when the heating is on.
Is this easy to fix to give me a year of extra life?
gas4you who posts here at more normal hours operates in your area and you can probably track him down from his profile if not his 0870 number on his on line shop which is regularly linked to.
At least he will be bound to do a good job for you at a reeasonable charge otherwise you would be telling us all about it.
Thanks Tony, but don't think I'd have a clue on one of these ancient boilers Another unhelpful fact for the op is that I couldn't look at anything for about 4 weeks at present! Never know it so busy for this time of year
Not mentioning anyone but I would suggest to the op not to employ firms from adverts in local evening press
The heating being on will have no effect on hot water flow.The flow rate depends whether you have a 75/80 version or the 100.
The 75/80 only had low flow rate( about 9 litres/min approx. if memory serves me right) which is a bit pi$$poor these days.
You need an engineer with a weir gauge to measure flow rate which can be adjusted on the boiler ( The plasic screw does tend to shear though).
Only other reason could be low cold water pressure or blockage in filter going into boiler.
Never had one get scaled up to such an extent that waterways blocked but then i don`t live in hard water area.
Thanks.. yes i do live in an especially hard water area. I have tried to adjust the throttle which i turned to full, and i have cleaned the little metal filter i think you mention.
Our water pressure is pretty high, so from what i am hearing there could be a scaling blockage, in conjunction with the flow switch which is susseptable to scaling issues .. i think it's time has come.
Thanks again.
if im thinking of the right boiler, they don't have a diverter as such they have a series of thermistas and switches. Could possibly have a build up crap round one of the sensors or possibly filter blocked..
