Can anyone help, i have a Gloworm Ultimate 70ff boiler, the system is Danfoss Heatplan with Prorgammer (2 x 2 port valves) according to the Heatplan wiring the boiler only needs Live, Neutral, Earth and a single Pump supply wire, also another wire if boiler needs a permanent live which i do not think it needs??? my question is, the boilers wiring diagram shows L,N.E supply from mains, L,N,E to the pump and two wires from the Programmer with the note * REMOVE RED LINK AND FIT SWITH LIVE FROM PROGRAMMER the two wires are connected to 1 x Thermostat/pump overrun and the other to the main pcb. i hope that this makes sense. can anyone tell me what the correct wiring should be as there is confusion between the Heatplan and the Boilers wiring diagrams
Rob
Rob
