Hi I have a 18sxi fitted 3 weeks ago. I know it has a frost control and I have a 3 port valve fitted with a room stat.
Should the boiler fire up when the timer is off and the room stat is off but the temperature outside is below 3 Degrees C as the boiler fires up and all the rads in the house get hot as the temp set on the boiler is 62 Degrees C.
If i dont want the boiler frost stat to fire up , should i set the timer on 24 hours and leave the room stat at 15 Degrees C therefore the rads will only heat up if the temp in the house falls below 15 Degrees ?
Need some silly advise as it gets too hot when the boiler fires up by itself ?
