Guys,
My mother seems to be having problems with her Glow Worm boiler. It was installed 2 years ago but to my recollection it's never worked properly.
The problem she seems to be having is that the boiler only seems to heat for a while before the burner goes to minimum. I have set the thermostat on the boiler to full (82 degrees), an external room stat is fitted and this is set on maximum.
The boiler fires on full (the display shows a flame with chevrons above it) and then at about 38-41 degrees it cuts out, the display then shows just the flame (no chevrons). The pump runs continously
I wonder if you could point me in the right direction, firstly do you think it's more likely a problem with the boiler, I can not see that the roomstat would make the boiler operate in such a manner.
Yours,
T
Yours,
T
