Hi i have just recently moved house and i am trying to adjust temps.
I have been told that premature boiler failure will occur unless the flow and return (at the boiler) is not set at approx 11 degree C diferential. The visible sight of plume also would indicate higher differentials.
Also i do have a stopcock at the cylinder which can be opened to allow circulation back to the boiler and therefore increase return temp.
Any thoughts or should i leave as is? (stopcock closed)
I havent got the boiler manual, so cannot confirm this reccomended temp difference, however it appears to be running ok with this closed!!!
Any Thoughts
Any Thoughts
