I have a problem with my Gloworm Swiftflow Combi boiler. When I use the H.W or C.H the pilot light goes out after approx 1 min. Boiler has been fine for last 2 years, and was last serviced nov 05.
On these boilers fan runs constant to provide air for the pilot to burn some have air pressure switch, some do not normally it is the thermo couple or/and the o/heat stat weak.Although had one last week the meter gov. was gone it was ok to light pilot but soon as burner lit w/p at meter dropped knocking pilot out. But really is corgi territory
