Recently had to drain the system a couple of times to fit a new rad after a bathroom refurb
Friday night I drained down and refilled but noticed it took longer than usual to re fill and pressurise (From the filling loop)
Anyway I got it to 1.5 bar and run the heating up then bled the rads and topped back up to 1.5 bar
I noticed later Friday that The pressure had risen to 4.6 bar and boiler locked out so I reduced the pressure back down but noticed that the overflow? Copper pipe outside was dripping (which I assumed was normal as the pressure was high)
Yesterday afternoon the pressure dropped and locked out at 0.5bar
so I completely drained down again what was left in the system and re did the whole procedure but have noticed that the overflow pipe just drips constantly outside now.
I am after a bit of advice on the issue as I assume the pressure will now drop slowly as the overflow is dripping constantly
From the mimirage of internet sites it seems to point in the direction of the expansion vessel may need re pressurising or the pressure valve being faulty and not closing after being open
I must add I am not a plumber but am a very competent diyer and can tackle most things but I need to gauge whether it is something straightforward that I can tackle or if I need to get a plumber in
as we know plumbers aren't cheap which is why I would be reluctant to pay if it is a simple thing but if it does need it I have no problem getting somebody in
