Hello everyone!
We have a problem with our Glowworm 50 tripping out the electrics.
Our boiler is in the garage. The hot water is on 24hrs a day and the heating comes in twice a day. The boiler is 4 years old. We put the central heating back on since end of september and everything was fine until about 3 weeks ago.
When I removed the white metal casing and the front inner panel, I realised there was water on various parts which was obviously tripping the electrics. (Thank goodness for RCD switch!).
I did not find a leak on any pipes within the boiler (or outside for that matter) but I have not opened the inner box where the box where the flame is... (and I'm not going to!)
At first I thought it was to do with the small plastic tank (for the condensation) which is found at the bottom of the boiler at the back. As it was full, I thought there was a blockage in the plastic tank or on the drain pipe. Took the tank out, cleaned it (it was a little mucky for some reasons), checked the pipe... only to realise that the fact that the tank was full of water was probably normal as there are 3 compartments within it and the water only escape through the drain if these 3 compartments are full. I suppose it is a way to make sure only cold-er water drains out...
In any case the water seem to come from the top of the boiler, above the fan. I took apart the elbow at the top and pulled out the flu (spelling?) pipe out of the air duct. (sorry my spelling may be dramatically wrong for these words - I hope you understand what I mean). The large square gasket between the elbow and the boiler is completely ruined. although I am not sure what purpose that gasket serves).
Anyway there was quite a lot of water in the air duct and the flu pipe. I dried everything and put everything back together. (Putting it down to extremely bad rain we had the week before which could have potentially gone into the air duct).
However only 3 or 4 days later, the whole electricity started tripping again, open the boiler and there was lots of condensation on all the panels inside. Took out the elbow with the flu pipe and both the flu pipe and the air duct were both very wet.
Now I have been now running the boiler for the past two weeks without the outer (white) casing and without the gray front panel. I don't know if it makes any difference, but I also regularly empty the condensation tank.
As everything is open, there are obviously no condensation happening inside and everything stays as dry as a bone. So it's working.
I can't see anything leaking from the fan and the fan seem to be working well as steam can clearly be seen coming out of the flu pipe on the other side of the wall.
I checked the flu pipe and the air duct at the week-end and there was some water in them (again).
So I don't know where to go from there. Any ideas?
I am convinced that if I put the front panel and the outer casing back on, condensation inside will start to trip the electrics again... Could it be the fan that is leaking? or not working properly?
All help would be really appreciated.
Many thanks,
David
XoioX
Many thanks,
David
XoioX
