- Joined
- 2 Feb 2007
- Messages
- 105
- Reaction score
- 0
- Country
Hi, im new here but i hope someone can lend some advice.
I have lived in my house for 6months now and have had little trouble with the boiler.
Now i keep having to press the reset button because it keeps tripping out on what i assume is overheat. It keeps doing this randomly, may last a week then another day trip out every half hour! before tripping out everything is normal.
I was told this is probably due to a doggy thermocouple - have had a look in the boiler today and it doesn't seem to be this. (i was told that a thermocouple would detect the heat change from cold to spark/ignition of the pilot light and cut off if there was not a rise in temp - ie pilot light not lit don't open main gas inlet). I could not see this obviously.
It does seem very dirty inside, not black with dirt or soot but a lot of flaky bits, mostly that have fallen from the heat exchanger.
I have now found this .PDF format instructions from glowworm: http://www.glow-worm.co.uk/manuals/pdf/Boilers/Ultimate50FF.pdf
on this i can see no mention of a thermocouple but searching online you can buy spares of them, which look like the thermostat control and thermostat cut off sensor/thermometers!? (page 39/40 of the .pdf) are these the same as thermocouples?
Could this be the problem or could it be something else.
How does the boiler know when to open the main gas valve after lighting the pilot?
Any advice would be good i will clean out the bits and see if that helps for now.
Kevin.
Kevin.
