Glowworm compact 100e no hot water
20 Aug 2014
Essex
Hi all,
I've been unable to get domestic hot water, the boiler just doesn't fire up when I turn on a hot tap.
Central heating works fine though
I've ordered a new DHW microswitch as it seemed a cheap option to try
Be grateful if anyone could share the common faults that might be causing it.
Fitted a brand new PCB a couple of years back so i doubt it would be this
Thanks for your time
Probably more the diaphragm rather than the microswitch. Microswitch easily tested using a multimeter.
