Hey up,
We moved into a new house 6 months ago which has a Glowworm Compact 80p boiler. Unfortunately we have no documentation to accompany the boiler which we believe was installed about 5 years ago.
The boiler has been fine all summer when we have required only hot water, however when we turned on the central heating the boiler seems to be tripping out (pilot light goes off)
The central heating works fine (all radiators heat to required temperature) for about an hour before the system trips off, although sometimes it trips off after 10 mins, other times a lot longer.
Can anyone shed light on what may be causing this. From reading around it could be some sort of overheat sensor which is faulty, or perhaps a stuck fan.
Any help would be greatly appreciated.
