Glowworm Economy PLus 30B Heating not working.
Discussion in 'Plumbing and Central Heating' started by su966, 22 Aug 2017.
  1. su966
    su966
    14 Dec 2009
    89
    Thanks Received:
    4
    Country:
    WE have a Glow worm boiler Economy Plus 30B. Hot water is working but central heating is not working. It has a Drayton Mid Position Actuator. It is stuck in Hot water position. It does not move to Central Heating Position.
    Bathroom Fitter was fitting Towel radiator. He did something in the boiler room. Since then it is showing this problem.
    Please give some help and advice.
  2. Sponsored Links
  3. Elkato531
    Elkato531
    22 Jul 2009
    1,097
    Thanks Received:
    281
    Sussex
    Country:
    You should check with the bathroom fitter first but motorised valves do fail and its probably coincidence. May have failed some time ago and you haven't noticed because the heating's been off for the summer. Replacing the accuator head on the drayton is simple enough (unless its an older one).
    First thing to check though is whether its just seized. The head can be removed by pressing a black clip. You should be able to move the spindle with a pair of pliers (only moves about a quarter turn or thereabouts. If its stiff, wiggling back and forward can free it up so its works for a while. Drayton valves seem prone to sticking so if your having to replace, a Honeywell would be a better bet.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
