Glowworm Energy 35C combi frost setting
8 Oct 2023
Can the frost setting temperature of a Glowworm Energy 35C combi boiler be changed ?
Currently, it is set at its default of 12 degrees C.
Thank you.
No. Its locked in the software. If the boilers in the garage or loft then there is every chance the boiler will run for periods over night when it is very cold.
Thanks SGM, I just wondered if the setting temp could be changed but I from what you say it’s fixed in the software. 12 degrees just seems a little too high compared to other boilers.
As already said by @ScottishGasMan , no it can not be altered but be aware this only protects the boiler, it will not protect attached pipework in the same area , they need additional protection
