I've got a gas Glowworm Fuelsaver MkII (Model 50R). An approximate sizing has shown that the boiler output is just enough (theoretically) for the original radiators and a double panelled one added recently.
The central heating has been poor for a while with downstairs radiators being warm/cold. When the system was drained, cleaned with Fernox and refilled the problem moved between radiators, but remained.
A friend helped me to power flush the system, which triggered a fault with the thermal cut out. However, thanks to the guys on this site we got it going again.
The boiler has now been serviced, but the radiator problem persists. Recent advice from a plumber was that the motorised valves were working OK, the pump sounded OK, but the boiler seemed to be 'cycling', an indication of poor flow. He also commented that the power flush should have been done at the pump and not at a radiator. I've since manually flushed each of the downstairs radiators with a hose, but with little improvement. The radiators do get warmer if the hot water is off, the thermostat on the hot water tank has also been replaced.
Any advice would be gratefully received.
