Wonder if any of you guys can help.
I drained down the heating circuit to do some work on the system (resite a couple of radiators), and i've ended up damaging the plastic o-ring/gasket on the drain off valve plug (by overtightening I guess). This is constantly leaking now when I refill the system, so I need to either get a new o-ring for the plug, or replace the whole drain off assembly. The o-ring/gasket is slightly cone shaped and the drain plug is about 3 cm long with threads on about 1cm of the end.
I couldn't get any part numbers from the glowworm manuals, so appreciate any help with part numbers or recommendations on what I should do.
Boiler: Glowworm Hideaway 80
Location of drain valve: about 2/3rds down on front-left of Boiler on Flow.
Cheers Guys
Cheers Guys
