Glowworm Micron 40ff problem
5 Feb 2008
Works fine for the hot water all the time.
However, the central heating, it only works 8 out of 10 times, sometimes you turn it on and nothing happens, however when this occurs if you turn the hot water on the radiators heat up fine, but turn the hot water off and the heating stops.
other times the heating works first time by itself,
very strange, any ideas?
thanks guys, did a bit of searching and seem that what it is.
Any ideas on a roguh cost to get to fixed (will probably need replaced?)
Just the actuator around £100-£120 + VAT, whole valve around £180-£200 + VAT
Theres a product re-call on Micron 40ff [also 50ff 60ff 70ff 80ff 100ff & 120ff] manufactured between 25th October 2006 and 2nd May 2007
The problem is something to do with a gas manifold that can leak after installation but doesn't show up in their testing procedure.
Ring 0800 793 8554 if you think yours may be affected. Phone call and modification are free.
