Ever since we put the heating back on, and timed for the up coming colder months (About 7 weekes ago), the external boiler water pump is constantly running. The boiler has been used all year on timed for Hot Water, so has not been inactive.
I have also noticed that the boiler will ignite for 30 seconds or so even though the timer control (In the Kitchen) says it should not come on.
EG Boiler came on at 10:14pm tonight even though timer says
Time 1 - 05:30am to 07:30am
Time 2 - 05:00pm to 08:00pm
Have tested room thermostat (Downstairs hall) by changing temp and boiler does not react. If outside above times.
Have noticed that the thermostat/PCB control box attached to the boiler (underneath) has a number of red LEDs inside it which are constanly on, not sure if this is correct or not, as never looked before the fault occured.
Have tested voltage between P an SL and is at 0v, but pump still running.
Any suggestions would be much appreciated.
PCB is single fuse design.
Regards Matt
Regards Matt
