We have a Glowworm Ultimate 50FF that was installed since the house was built (2000). Since the first boiler breakdown the boiler seems to have been a bit of enigma for engineers to correctly diagnose and fix faults.
Now years late it seems to have developed a habit of both struggling to light and only lighting if both heating and hot water is requested. Given we don't use the heating unless manually requested we didn't really notice until the weather started to get colder. Short term fix was to turn both on and hope it would eventually light.
Long term fix is our Home Emergency Cover from our house insurers. We are now on our 4th visit by 3 different engineers over 2 separate call outs! Everything is covered but starting to be disappointed that the parts and time been spent on it hasn't got to be fully in order.
After today's visit the boiler seems to have no issue lighting in response to request for hot water (as soon as requested). However with that so much improved the fact it never even bothers to do anything if heating is requested on its own is now much more obvious.
My understanding is some systems (gravity feed) can only have heating when the hot water is on. We have been able to use our programmer for two decades to request heat or hot water independently.
I have just checked the following combinations
Boiler does not attempt to start if;
* Heating requested, hall thermostat high
* Heating requested, hall thermostat high, hot water requested, cylinder temp low
Boiler starts immediately if;
* Hot water requested, cylinder temp high
* Heating requested, hall thermostat high, hot water requested, cylinder temp high
Kit involved
* Boiler = Glowworm Ultimate 50FF
* Programmer = ChannelPlus XL Model H21
* Pump† = GRUNDFOS UPS3 15-50/65 130
* Mid Position Actuator = Code GBMVSP-23
* Thermostat = Siemens Landis & Staefa (unknown model)
Annoyingly they don't give you paperwork any more telling you what was done and over 4 visits it's hard to keep track of everything.
† This is not the original pump as during these recent visits it had to be replaced (started to make an awful noise)
Based on the setup is there anything trivial or a common fault that might be causing this? My uneducated guess is something been incorrectly re-commissioned during one of the visits on the controls side. Hopefully if I hint strong enough the next visit might be the 5th and final!
Kit involved
