Glued laminated timber boards
I cannot find anything with a minimum of these dimensions.
length = 1664 mm
height = 380 mm
depth = 27 mm
they come out at 18mm i think it is
what exactly are you making you could double up on the edge with 2x1" par [19x44mm] if your after a chunkey look
B&Q sell 22mm, I know this because I'm about to butcher a length for a shelf in my downstairs cloakroom.
It's not cheap, however.
And here's a cut and pasted chunk from the Champion's Timber brochure...
Solid Pine Board
Manufactured using Scandinavian Redwood Pine, not the cheaper less
attractive spruce. Constructed from narrow widths of kiln dried timber
averaging around 12% moisture content, which is then edge-glued togeth
achieving a very strong board, in dimensions wider than can be naturally
grown.
• cut it, carve it, shape it . . . no need for edging strips
• used for making furniture, built-in wardrobes, worktops, shelving, st
treads etc
Important
To maintain stability we recommend all surfaces and all edges, after cutt
and shaping, are sealed with either the appropriate coats of paint or 2-3
coats of good quality waterproof polyurethane or varnish. Pine Board is
not suitable for exterior use. Do not allow this product to stand in a
centrally heated environment without having first sealed and fixed.
18mm Thick
Code Size
41217TLM 1200 x 300mm
41617TLM 1200 x 400mm
42017TLM 1200 x 500mm
42417TLM 1200 x 600mm
6917TLM 1800 x 225mm
61217TLM 1800 x 300mm
61617TLM 1800 x 400mm
62017TLM 1800 x 500mm
62417TLM 1800 x 600mm
8917TLM 2400 x 225mm
81217TLM 2400 x 300mm
81617TLM 2400 x 400mm
82017TLM 2400 x 500mm
82417TLM 2400 x 600mm
28mm Thick
Code Size
41227TLM 1200 x 300mm
42427TLM 1200 x 600mm
61227TLM 1800 x 300mm
62427TLM 1800 x 600mm
81227TLM 2400 x 300mm
81627TLM 2400 x 400mm
82027TLM 2400 x 500mm
82427TLM 2400 x 600mm
You need the sheet material brochure, not the timber and mouldings one.
I can see how I might have confused the issue by saying "Champion's Timber brochure", but that's the company name, hence the capital.
