- Joined
- 27 Jan 2008
- Messages
- 28,385
- Reaction score
- 3,452
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a small problem hall cools down too slowly, i.e. slower than the living room, so these would help, but a lot of money to fork out if they don't work, already been caught out by Nest, it claimed Energenie MiHome TRV heads worked with it, and they don't, seems support withdrawn when Google took over Nest, I have Nest Gen 3.
Up to now only seen for US market, their Nest is different to ours. I was not sure if posting in electric UK or plumbing, but it is clearly electric even if for central heating.
Nest Website said:Which Nest thermostats are compatible with the Nest Temperature Sensor?
The Nest Temperature Sensor works with the following thermostats:
For the following countries:
- Nest Learning Thermostat, 3rd generation
- Nest Thermostat E
If you’re not sure which Nest thermostat you have, see the following article:
- United States
- Canada
- Mexico
">How to tell which Nest thermostat you have >
Important: As long as you purchased your thermostat from a retailer in one of the countries listed above, it should work with the sensor. Thermostats designed for use in other countries, however, are not currently compatible with the sensor. The app will prevent you from adding the sensor to a thermostat designed for use in any other country.
