To give you hot water from start-up, there is a fixed thermostat that heats up the heatstore. Is the heatstore getting hot?
Developments
No heating this morning , checked the boiler and the red light for the pump was on but it had tripped out reset and its working but i'm giving up and calling an engineer
I am so fed up with this boiler ever since new i'm lucky to get a period of 9 months without it breaking down
It kept losing pressure = stuck pressure releif valve took numerous visits to diagnose
It kept sooting up = repeated engineers had fitted wrong injector
It kept losing pressure 2 = Expansion vessel faulty
Wouldnt fire = due to sooting
Wouldnt fire2 = due to the light sensitive diode being faulty
Its now 6 years old and broken again so new thread looms
I wish i could go gas![]()
Well still no return calls from the 3 engineers i called yesterday apart from one did call and said he could service it but couldnt touch the divertor valve as he wasnt a plumber ???
Its all ok saying there are muppets or bad engineers around here but this is all i have was even looking at doing the course myself but seems there is no entry unless you get taken on as an apprentice so that door seems closed
