Grant Vortex Eco stuck on
14 Jul 2018
I am an Electrician and I have just been called to a Grant Vortex Eco that will not turn off.
All the external controls are correct. The 2 control wires from the wiring centre to the boiler switch the 230v on and off when you request HW or CH. However, with both of them off the boiler still runs. I believe it is the CH that is stuck on because the radiators get hot. It is safe enough because it does turn off with the boiler thermostat when the rads are up to temperature.
My guess is a stuck control relay, I told her to call a heating engineer but no one will go out until the new year. Anyone any advice on the internal electrics of these particular boilers? Thanks.
Internal wall hung and non system going on the pictures on the grant spares site. The control panel is a MPCBS108
I thought the frost stats wired into the wiring centre but if it is somewhere else then I will check it.
Thank you.
Thank you. I just got back from the customers and the CH valve is gone. I observed the HW valve moving the arm but the CH one was dead. I moved the arm by hand and it turned off the boiler but there was zero resistance so the motor is clearly shot.
Last question. It is a Drayton ZA5 valve and I can get a new one locally, can I just change the head or is life not that simple?
Thanks again for educating a sparky.
