Gravity fed electric shower
4 Aug 2006
Lancashire
:roll: Can anyone tell me if I can feed my electric shower from a header tank stored in the loft. This is to guarantee a consistent water pressure to the shower as the pressure in the area is very poor
i have seen this done before but it depends on the minimum flow rate and pressure as situated in the manufacturers specifications e.g 1 meter from your header tank to your shower head is equall to about 0.1 bar so if your tank is 5 meters high without any pipe restrictions it would be 0.5 bar so check the manual and read the specs
If your head of pressure is not enough you can install a single impeller pump to feed the shower.
Pete
It's not so simple. This question has been asked and answered very recently so look down the topic index.
Yes, sure. Mira make a pumped one too. but he's talking about using his existing shower, which isn't likely to work.
Yes, I agree. It would be a waste of money, better put towards a replacement unit imho. What do you make of the Mira? I was going to get one but couldn't get any sense out of plumbcentre, so got the 8.5kW from TLC instead.
Never installed or even seen a pumped one, but in general I would say that Mira are better quality.
