gravity fed hot water cylinder
10 May 2007
Isle of Wight
Ive gotta gravity fed hot water cylinder; central heating fully pumped!
The pipes from the boiler [oil fired] get hot, but the water in the cylinder remains cold;
Should I assume there is a blockage in the pipe work to the cylinder; Im told this is quite a common fault on gravity fed systems. There is also a lot of black magnite sludge in the system :(
Any idears on how to clear it, besides a power flush as the cylinder looks old, and might not withstand it!
If you bleed the highest level vent on a radiator (or better, the feed to the cylinder) does water squirt out vigorously?
When you look in the Feed & Exansion tank, how much water does it have in it?
If you draw a pint of water out of the drain cock, does the same amount flow into the F&E tank?
Have you got a strong magnet?
First place I'd look if you have followed johnd advice and are sure you have a blockage is the T where the cold fill joins the gravity return, after that the T to the vent.
