I am planning on fitting a gravity fed 'deluge shower kit' and see quite different information on manufactures specs.
Currently I have a simple bath mixer tap with shower attachment, and in the long term will be planning on fitting a power shower (have cold and hot water tanks) but as a short term measure was going to replace the shower attachment with a "Deluge shower riser rail kit" - as the current shower attachment doesn't even have a riser rail. These kits seem to have a short length of hose which connects to the existing shower attachment connection on the mixer tap (assume these are all standard 0.5 inch connectors)
The hot water tank is on the same level (first floor flat) and the cold water tank is in the loft, giving approx 2 metres Head.
My problem is the disparity in "minimum working pressures" given by different suppliers for a simple riser rail shower head. and was wondering whether I should heed their advice or ignore it. The current shower attachement gives an OK pressure (as good as I would expect from 2 metres head).
Screwfix offer one type with a switchable separate handset (part 22414) which requires 0.35 Bar - which is 3.5 metres from my maths - not possible for a gravity fed shower only one floor below the tank.
But Screwfix also offer another type without the switchable handset (Part 21824) which claims to work of 0.2Bar (2 metres, so seems more feasible) but cannot see why this would be different - is it base on pressure lost going through the handset switch?
To further complicate things, Argos sell an almost identical unit (part 832/1444) which claims to need 20PSi. Thats 1.37 Bar, or 13.7 metres of head - are they serious?
Does anyone know why this would be? is there any difference between these units in reality? I've added the links below to the three items in case anyone would like to check them out
Screwfix 0.35Bar
http://www.screwfix.com/app/sfd/cat...WYGALRCJO2C3CJ0Q?cId=101204&ts=29431&id=22414
Screwfix 0.2Bar
http://www.screwfix.com/app/sfd/cat...WYGALRCJO2C3CJ0Q?cId=101204&ts=29431&id=21824
Argos
http://www.argos.co.uk/static/Product/partNumber/8321444.htm
Dave
Screwfix 0.35Bar
Screwfix 0.2Bar
Argos
Dave
