i have just fitted a new bathroom suite and installed a low pressure bar mixer shower. I originally thought my boiler was a combi (fitted about 2 years ago) but it is infact a conventional boiler with a hotwater tank.
I am now a little concerned with regards the pressure the shower will have. I have fitted all the pipes behind the plaster but haven't made the final connections yet. I went to the plumbers today and they said it would be advisable to fit a "surrey flang" or was it essex ?
They showed me 2 versions, one with what looks like a syphon tube and the other that you cut a hole in the tank.
What i want to know is , Do i really need one of these ? Because it is a gravity fed shower, I intend raising the header tank in the loft at least another couple of feet. The guy at the plumbers shop said that every 12" i rase the tank will greatly improve the pressure. Also he said i should feed the cold from the header tank.
I was thinking of taking a cold feed from the gravity supply to the hot tank but i then realised if i did that then the full gravity pressure would be split between hot and cold>
Do i make a new hole in the cold water tank and supply cold separately ?
Thanks in advance to any help.
