This system was installed in the 70s - a basic gravity hot-water system fed directly from the boiler.
There's also a pumped heating system, using separate connections from the boiler. This works fine.
No diverter valves, as far as I know. Both systems use different outlets on the boiler.
Boiler is at ground level; hot tank is on first floor, open header tank in the loft.
About 5 years ago I had to have the boiler changed, the plumbers fitted a new Glowworm hideaway FF cast iron boiler.
The plumbers did say I should have 28mm pipes to/from the boiler, but my system only ever had 22mm ones and it would have been a nightmare to swap, involving ripping out wardrobes, floorboards, ceilings etc.
They also fitted an electric valve to the outlet from the HW tank, controlled by a thermostat fitted to the side of the tank.
Anyway, it all worked nicely for a couple of years.
Then the hot water tank coil sprung a leak, so I replaced the tank myself. The new tank is smaller capacity, but the biggest difference was that the top gravity pipe was not as high as the old tank.
Aside from that, the plumbing connections are exactly as per the old tank.
I made sure that all pipes run horizontally, just like the originals.
(no diverting old pipework upwards etc.) to avoid airlocks.
Ever since, we occasionally don't get hot water.
Particularly if somebody runs off all the hot water to have a bath.
It seems the gravity circuit isn't starting when it should.
Feeling the pipes near the boiler, when it's not working it seems that the gravity pipes (both flow and feed) are getting hot at the same time, so the gravity circuit can't start circulating.
The pipes near the tank don't get hot at all.
There are no vents near the tank, but I have tried cracking the top pipe open to vent it, and all I get is water.
I can get it started by putting a hosepipe onto the vent pipe in the loft and blasting water around with the rads turned off. The system then works until somebody runs off all the hot water again.
Blasting water around this way doesn't seem to cause any airbubbles in the open tank, so I don't think I'm shifting airlocks.
The electric motor on the tank valve seems to be operating correctly when I play with the tank thermostat.
Or is it simply a particularly stubborn airlock?
Do I now need a one-way valve in the gravity circuit, due to the height differences in piping to the new tank?
Should I think about fitting a low-powered pump into the gravity circuit?
Have I missed something obvious?
