Green Oak Balcony with glass
17 Sep 2007
Oxford
We are having a green oak balcony made for our barn. we want laminated glass panels used in the sides, attached with metal brackets, so there is a gap between wood and glass. Has anyone any experience of this? Our joiner is worried that with the wood movement the glass would break. He has suggested the glass inserted with no gap, but it doesn't look so good.
3 Nov 2006
Bedfordshire
If the glass is fixed with rigid brackets then shrinkage and movement in the timber will put the glass under stress.
A flexible bracket will avoid this.
Industrial or automotive anti vibration mounts (which are two fixing plates or stiuds linked by a firm but flexible rubber or similar material) may provide a solution.
B
breezer
no idea what they are called, but dont they have like two cemi cirles (one either side of the glass) at various points around said glass holding the glass, so each can expand and contract but the glass stays secure
google is your friend :cool:
they do like i said
i found them here
other supplies of glass thingy's are avialable
thanks is always nice
13 Jan 2008
Hampshire
use toughened glass and attach directly to the green oak. This is now standard practice in green oak construction. If you get the green oak construction right there will be no problem with toughened glass.
hope this helps
