Grohe electric shower issue
7 Feb 2008
Northumberland
I have a Grohe Tempesta 8.5kW shower - it's not used often.
When the shower is switched off, the hot water flow immediately stops. Occasionally it gives a spurt of very hot water seconds later (I'm told).
Switching it back on again, the auto reset lamp is lit for a while, and it passes only cold water until the lamp goes out - maybe 15 sec or so.
I seem to recall it used to run for a few seconds before shutting down, presumably to lose hot water from the water boiler.
I know that this shower has a 'phased shut down' relay, and also a 'phased shut down' PCB. I don't know how reliable these things are.
If anyone could point me in the right direction to sort this, I'd be very grateful!
Cheers and have a good evening everyone
John :)
It seemes to be behaving like the normal non phased shower, when you switch one of these off the water stops immediately but you will get a dribble (but not a spurt) of hot water for a few seconds, if you listen (with shower off) you will hear a click ~ 10 seconds later, this is the thermal cut out, TCO, operating, it probably takes a 1/2 hour or more to reset if you don't switch the shower back on. If you do switch on the shower a few seconds after stopping it then it will run extremely hot for a few seconds, then run cold (TCO) has operated for maybe 10 secs and then will heat up normally over 10/15 secs. If I know that someone is waiting (not very often) to use the shower straight away, then I switch the power selector to cold for ~ 10 secs before switching off, after switching off, I then return the power switch to normal.
This won't fix the above shower though.
Thanks John
I’m tempted to replace the phased PCB, the fault seems to be in that area, and I would have thought that a relay fault would cause the shower to not function at all or to be flowing constantly.
The darn thing seems to be obsolete now but these parts are available.
I like your idea of running the shower cool, a good safety technique.
I appreciate your interest!
Regards
John
