Hello,
I have an unvented boiler system with cold water tank in loft with hot water cylinder in airing cupboard.
Recently my outlet pipe on outside wall was pouring water ,I changed the Ballcock in cold water storage however problem persisted.
I then changed the strap on thermostat on cylinder which seems to have sorted that issue.
My wireless Grohe pumped shower,pump in attic,it is ceiling fed had displayed error 13 which appeared to be water too hot so it would activate with the anti scald shut off.
I have checked inlet filters going into pump but they seemed fine.
The pump is non serviceable so I am wondering if it is completely broken.
When the thermostat was fitted the shower was displaying error 11(water too cold) then error 13(water to hot).
I have tried using the controller to open inlet v which can help with forcing solenoid a open I think and the water coming out is very hot.
I have tried taking shower head off and turning water down to low temp and the water is boiling.
It just does not seem to be allowing cold water through.
Has anyone any ideas or do you think the pump has had it.
Thank you for reading.
